Pour ceux qui veulent faire l'Open
Je reprends le post (donc les commentaires de Tulkas)
Team creation
- 1100k for a standard building a team and the inducements
- minimum 11 players must be included in a team and no more than 16 including star Players
- At least 11 standard roster players before any star Player
- each team may buy 0-1 NAF-approved star Players
- 0-8 Re-Rolls
- Assistant coaches - Cheerleaders - 0-1
Apothecary or Igor, depending on race
- 0-9 Fan Factor
- Inducements. The cost will be as following and will count for all 6 games
- 0-2 Bloodweiser Kegs for each 50 kgp
- 0-3 Bribes for each 100 kgp, for Goblins only for each 50 kgp
- 0-1 Masterchef for 300 kgp, for Halfings only 100 kgp
- 0-1 NAF-approved star players for their regular cost
Additonal cash: You can use additonal cash afer spending whole starting budget. Each non spent amount from starting budget is lost and cannot be used with additonal one.
- each team has additonal cash based on their Tier that can be spent on additonal skills, players, star players and inducements
- the cost of the additonal skill is:
20k for normal skill
30k for double skills
- maximum one player in each team can stack an additonal skill, the second of the stacked skill costs 30k, both skills have to be normal skills
- maximum one player in each team from tier 1-3 can have one double skill
- maximum two players in each team from tier 4-6 can have one double skill
- star players may not receive additonal skills
- the Skill "Piling On" will be used according to Death Zone 1, i.e. Team Re-Roll is required to use
Tiers
Tier 1 - 100k for skills/players/star players/inducements: Amazons, Dark Elves, Dwarves, Lizardmen, Norse, Wood Elves, Undead
Tier 2 - 120k for skills/players/star players/inducements: Chaos Dwarves, Orcs, Skaven, Necromantc
Tier 3 - 140k for skills/players/star players/inducements: Bretonnians, Humans, Chaos
Tier 4 - 170k for skills/players/star players/inducements: Chaos Renegades, Elf Union, High Elves, Khemri, Nurgle, Slann
Tier 5 - 200k for skills/players/star players/inducements: Daemons of Khorne, Underworld Denizens, Vampires
Tier 6 - 230k for skills/players/star players/inducements: Goblins, Halfings, Ogres
Scoring: The event will give priority to team wins over individual wins
Should a Team win their tie they will get 2 Points
Should a Team Draw their tie they will get 1 Point
Should a Team Lose their tie they will get 0 Point
In the event of an equal score, the first tie breaker will be individual score based on the W/D/L of the individuals in the team
An individual win is worth 2 points
A draw is worth 1 Point
A loss worth 0 Points
The second tie breaker will be Head to Head for the respectve Natons or Teams
The third tie breaker will be Strength of Schedule
The fourth tie breaker will be Team NET TD + NET CAS
The fifth tie breaker will be coin toss
C'est la porte ouverte à la diversité, aux équipes d'elfes, puis donc de nains pour les tacler !!! En fait, je n'en sais rien, je manque d'expérience pour visualiser les équipes qui y gagnent !
C'est quant qu'on quitte notre unité nationale derrière les Push Push pour notre régionalisme, local, bio et solidaire derrière nos copains de ligue ?
-On va quand même pas sélectionner un Azes avec un carton jaune au cul ?
-Et faudrait imposer une période de jeune sexuel, ainsi que des tests de grossesse dès mars pour éviter les forfaits et annulations.
-Vivent les kermesses
-Power rosters !!!
-Vive le tiers 3
-Vampire tiers 5 Appellez Quizz !!
Euro
Re: Euro
Putain il est bon ce format :
Comme ça je dirai
Woodies
elfe noir
elfe
skaven
Amazone roxanna
MV
Saurus
Bretonnien griff à tester
Comme ça je dirai
Woodies
elfe noir
elfe
skaven
Amazone roxanna
MV
Saurus
Re: Euro
en tout cas, on risque de ne pas trop voir de compétences écrasement
Re: Euro
Ndc c'est de la daube, regardez les résultats de la WC... On avait un format similaire.
Et c'est pas parce qu'ils ont tacle qu'ils ont un bon ratio contre les elfes...
- Tom
- N° NAF : 15578
Re: Euro
Les bretos sont enfin à leur place, en tiers 1 ils étaient hors sujet.
Par contre les elfes pros en tiers 4 c'est peut être un peu overkill. M'est avis que les rédacteurs du règlement n'ont pas rencontré assez de compos avec Eldril à la WC
Re: Euro
Les EP tiers 4 avec eldril
J'en connais au moins 3 à qui ça va bien plaire
Pour le coup bretos 124 ça permet de placer un griff beaucoup plus sereinement
Ça fait plaisir de voir un format si ouvert.
Les polonais avaient dit qu'ils le feraient, brawo!
Re: Euro
attention au format c'est 110 puis seulement ensuite l'additionnal cash
Additonal cash: You can use additonal cash afer spending whole starting budget. Each non spent amount from starting budget is lost and cannot be used with additional one.
pour les bretonniens (et elfe) c'est création d'équipe à 110 puis seulement ensuite on peut dépenser les 140 supplémentaires et pour rentrer le champion faut être déjà 11, ça limite un peu plus.
pas moyen de faire des roster à 111 ou 112 par exemple ^^
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 3 invités
